It is currently Sun 24. Nov 2024 19:28:53
[ 3 posts ] |
Jeeprogue
Posted: Thu 09. Aug 2018 1:16:06 |
The manual specifies that the Geo-Link must be mounted perfectly horizontally, On models like the 470L that have a forward rake when sitting on the ground, the tail boom is not horizontal. It is however horizontal while flying, will this create any issues?
Posted: Thu 09. Aug 2018 21:17:45 |
Unfortunately it is necessary to mount the GeoLink so that it is parallel with rotor blades or perpendicular to the main shaft. It will affect RTH, Geo-fence and Position Hold.
You can find the exact angle with help of protractor in the GeoLink settings window.
dogbreath
Posted: Fri 10. Aug 2018 17:17:36 |
Joined: Wed 20. Jan 2016 20:23:36 Posts: 17 Location: DFW Texas
The rake will not affect performance. Prop up the front skids to get the FBL level, then level the Geolink to the FBL during setup. As long as Geolink is "parallel" to FBL, it will fly correctly. Heli's with boom covers that aren't parallel to the FBL are more problematic and will require some shimming. Dan
_________________ Synergy 516, 556 stretch, 696.
[ 3 posts ] |
Users browsing this forum: No registered users and 62 guests |
