It is currently Sun 24. Nov 2024 20:30:42
PostPosted: Sat 28. Jul 2018 19:43:09
Hello, I would like to use HW 100 V4 Telemetry. It works for RPM, Vibrations, Main Battery Voltage, Temp1 - but not values regarding to Ampere - no current value , no consumed Capacity.
Did you have any idea what's wrong with it ?
HW has been updated to latest version, same at Spirit Pro and FrSky componentens
thx and br
siggi
PostPosted: Sat 28. Jul 2018 20:23:57
100A V4? To my knowledge there is only a 100A V3. This doesn't have full telemetry.
PostPosted: Sat 28. Jul 2018 20:37:36
Sorry, confusing you . It's 80A Platinum V4.
PostPosted: Sat 28. Jul 2018 22:21:47
are you checking it in the flight, am I correct?
If no, then this is the only problem :)
It will not show you any good value as the ESC current sensors are not that sensitive.
When flying, it will be OK.
PostPosted: Sat 28. Jul 2018 22:32:35
He , you are right. Currently system is running at the ground only and without blades.
I will check it tomorrow , coming back with feedback.
thx so far and br siggi
PostPosted: Sun 29. Jul 2018 19:10:09
Yes, you are right everything is fine in case flying with it.
And - knowing this brings one question on the table. Is ESC Ampere Measurement less precise ?
br Siggi
PostPosted: Mon 06. Aug 2018 14:24:45
hello guys , coming back to my post.
Another issue -
RPM is fine
Consumed A - seems to be less than used
current A - isn't shown
RB1 - Lipo V is fine
fuel / Vib - no value
tmp1 - is fine
everything is properly configured
thx and br siggi
PostPosted: Mon 06. Aug 2018 15:45:53
are you sure you are checking the current after flight?
Consumed Capacity can be fixed by correction factor in the Telemetry window.
Vibes should be there when flying in normal flight mode.
PostPosted: Mon 06. Aug 2018 18:14:36
No I checked current value during flight , becuase I expected as it called current value.
Hint -I'm using stand FrSky OS without lua - installation.
I'm wrong expecting that ?
PostPosted: Tue 07. Aug 2018 19:48:34
I am afraid but there could be issues in FrOS as it is still relatively new.
With OpenTX all should work correctly.
Maybe you can check if there is an update for FrOS?
Users browsing this forum: No registered users and 65 guests
