It is currently Sun 24. Nov 2024 19:33:24
PostPosted: Thu 19. Jul 2018 18:04:57
Hello I would like to give a general suggestion to all, update the bootloader of Unit spirit when you do an update,specifically 2.4.3, because before I had done this update I always had problems of bind, between my DX8 GEN 2 and lot off Spektrum satellites, beyond with the 4649t. I read the end of the manual better,
relating to the spektrum integration part and as soon as I updated the bootloader I had no bind problems.finish problem
So it is important because if the bootloader is NOT updated the bind also with the 4649t is possible the same, but the unit is not Work okay after, cut off esc, radio signal loss etc, I'm convincing that I lost more than once the radio signal on my satellites for this too.
I await confirmation from Tomas.ciao to everyone
Pino
PostPosted: Tue 24. Jul 2018 7:12:22
Thank you.
Yes, this is what is written in our Spektrum integration guide.
But there are not too many units with old bootloader, so it is only relevant for older units.
PostPosted: Tue 24. Jul 2018 14:42:58
ZeXx86 wrote:
Thank you.
I agree but I had the 2.4.3 firm, and the bootloader I have not updated, I had a sea of ​​problems, (lost signal-cut off esc-reblinding random etc etc) as soon as I updated the bootloader all gone.I see this update be a must along with the fimrware 2.4.3,regardless if you use the spm4649T .also the satellites suffer the old bootloader on 2.4.3 with random loss signal.
Users browsing this forum: No registered users and 72 guests
