Quote:
you can't bail out since bailout only is available if throttle is over 12%, doesn't it? The only way to bail out from a auto is using throttle hold and setting throttle slightly above 12%, doesn't it?
Yes, you are right.
But with simple trick it is possible to allow bailout even if motor was stopped completely. This can be done by decreasing Throttle Range - Minimum limit to the point when motor is not spinning even with 12% TC.
Quote:
can BT module be used in conjunction with the PC application?
Oficially this is not supported. Bluetooth module is for smartphones and tablets. On the other hand Wifi-Link modules support this with no problem. So you can completely replace USB interface with it and there are also many more features available with this module.
