It is currently Sun 24. Nov 2024 20:33:05
PostPosted: Tue 24. Jul 2018 8:43:42
I consider switching to OpenTX (from Spektrum) and I'm confused about wiring. It's written that to use integration with OpenTX (includes telemetry) I have to connect it to the SYS port. Wifi link also uses SYS port. Does it mean I cannot have both? Or need some Y-cable?
Update: I'm using Spirit Pro if this matters.
PostPosted: Tue 24. Jul 2018 9:00:50
you can use both, but not at the same time since OpenTX integration is using same port.
Y-cable will unfortunately not work.
PostPosted: Tue 24. Jul 2018 10:39:53
You mean I can use both but need to reconnect the cables, right?
Is there something missing in OpenTX menus comparing to wifi? I mean things you would be interested to check after flight.. I imagine you maybe can't do vibration analysis with openTX scripts, but can you review the flight log?
PostPosted: Tue 24. Jul 2018 10:43:18
Yes, you can review flight logs in the radio.
There is not absolutely everything (for example special functions in the Channels menu) but very likely enough for daily usage :)
PostPosted: Wed 08. Aug 2018 22:57:28
I'm using it now on a daily basis but wondering... Whenever I review the log over the Lua script, I see same log with very long length (1700 s.) and it says it is "previous". Might be some bench testing. And I do it right after flight. Does this mean my current flight did not have any problems? Is there a way to get rid of this "previous" log and see current one instead?
Sent from my SM-N950F using Tapatalk
PostPosted: Thu 09. Aug 2018 21:19:00
if you can see Previous flight, then it was from some bench testing probably. But right after viewing the previous flight, you can enter the flight log again and you will see Current flight log.
Then you will see everything that happened in the actual flight.
PostPosted: Fri 10. Aug 2018 8:44:41
Well the thing is, I made around 10 flights recently, but I always see the same very long "previous" flight log when I check the log. I it that I have to read it to the end maybe? It loads slowly because is very long..
Users browsing this forum: No registered users and 61 guests
