It is currently Sat 23. Nov 2024 13:28:08
PostPosted: Fri 13. Jul 2018 19:35:03
Hi I have a problem with telemetry, I use a jeti rex6 and kontronik kolibri 140 I would like to have spirit and esc telemetry but if I have the spirit via exbus and the controller telemetry on the other ex bus port the spirit telemetry does not work properly. Can I also run kolibri telemetry over spirit?
Gesendet von meinem SM-G950F mit Tapatalk
PostPosted: Sun 15. Jul 2018 15:51:31
at the moment no, but it will work very soon directly over Spirit.
Maybe receiver port is configured in some bad way. There are few options how to configure EX BUS port in the receiver. One option is directly dedicated for telemetry sensors.
PostPosted: Mon 16. Jul 2018 9:11:28
I have tried several receivers, always the same problem.
I have contacted jeti and received an answer: please contact Spirit for help.
PostPosted: Wed 21. Nov 2018 8:15:16
Good morning,
is there some news about Kolibri telemetry directly over Spirit?
David
PostPosted: Wed 21. Nov 2018 15:32:42
Yes, it will be supported in the upcoming firmware.
In the following days there will be also new telemetry cable which will allow usage of all radios. So it will work also with OpenTX, HoTT and others.
