It is currently Fri 22. Nov 2024 0:54:07
PostPosted: Thu 05. Jul 2018 22:06:31
Had to take one of my Spirit Pro from one helicopter to try it out on a plane. The last one I bought haven't arrived yet and i'm really curious, worked perfect on the helicopter.
It's strange I can't change to Bank 2, Can do it from 0 to 1 and back, can't go to 2, Please look at the short video on youtube
https://www.youtube.com/watch?v=PO5H-NVLH5Y
Edit:
I can change bank while flying, I can't do it in the software to configure bank 2
same problem on 2 different computers
 Post subject: Re: Can't Change Bank.
PostPosted: Fri 06. Jul 2018 11:12:09
it look like some settings are corrupted in Bank 2 for unknown reason. Maybe during loading from computer or because it was not Factory resetted after flashing Aero firmware.
I recommend to save settings from all banks if possible to your computer.
Then perform Factory reset in the Backup tab. And then load the settings from Bank 0, then Bank 1 (after switching to Bank 1) and then Bank 2 (after switching to Bank 2).
This should solve it.
PostPosted: Fri 06. Jul 2018 17:59:27
Done!
Thank you for the fast reply!
Made a backup of the settings, did a factory reset and restored the settings, solved it.
Didn't though of doing a factory reset after changing to aero firmware, makes sense.
Performance is impressive!
I have noticed something that for me is totally secondary, when choosing to use a separate channel for rescue or stabilization you still loose gain rate.
Users browsing this forum: No registered users and 8 guests
