Hello everyone.I'm desperate because I do not come to the head of a situation, and I no longer know what to think.in practice I have a micro spirit on a trex 250, and I have a new regulator Castle talon 25 amp and new a ubec from 3a, new servos (Savox) , and a Radio Spektrum dx8 gen2.ho also the grounding system,tail with motor support, i have check continuity and all work perfect... but I already lost the radio signal with the satellites 3 times and I changed 3 different satellites, two were fake, I was convinced that they were the ones, the last one took new and original, specifically a spm4648 autobind, and even with this last, I found the radio by the receiver, and from the log of the control unit, I find the voice receiver lost signal, just before flying just connect the battery at heli, so I exclude categorically the ESD ON THE BELT.I also changed the receiver's cables, got some new and better, moved the bec, the regulator,(far from satellite) I took every precaution possible, and I always find myself after a while that the satellites, lose the signal and not they are more good in general. I read all the forum, on similar problems, and I followed the letter all the advice when similar situations happen. I'm whipped, I do not know if I change radio and system, the radio is new is a dx8 gen 2, never fall or other, and on other models with the satellites have never had problems, similar, I talk about drones.What can I do to solve? if I wanted to use a receiver spektrum, not the satellites this time, which one would you recommend? how many channel? I also attached a scrEenshot of the log, and the strange thing is that I lose the signal of the receiver immediately, then low power, but everything works well, and the lipo is charged, then I disconnect the battery, connect again and the log is clean without advice(ALL GREEN) e WITH THE SAME BATTERY .all cables are new and in order and I have no false contact.
Attachments: |
