It is currently Sun 24. Nov 2024 17:36:41
PostPosted: Tue 19. Jun 2018 8:44:30
Hello service team,
I have smallest spirit system as well - and i would like to use it for Goblin 380 KSE becuase it's tiny and fine. I know - product documentation says "should be used from 130-250".
What did you think about it. Is it possible to use it for this Goblin? What's my risk trying it?
thanks in advance and br Siggi
PostPosted: Tue 19. Jun 2018 15:52:51
it should work well. The only risk is that you might loose power as the JST cables could be not up the task. But this is very dependent on used servos.
I recommend to not use BK servos and/or higher BEC voltage to be safe.
PostPosted: Tue 19. Jun 2018 17:38:52
Hello serviceteam,
I would like to use MKS HV93 and MKS HV9780, HobbyWing 80 V4 with 7,5 V at BEC output.
Would that be fine ?
thanks in advance and br siggi
PostPosted: Wed 20. Jun 2018 17:40:06
It should work well, but we cant guarantee it.
It could work well also on 500 class heli as it was in our testing.
Users browsing this forum: Google [Bot], mainstreet and 73 guests
