It is currently Sun 24. Nov 2024 17:22:19
[ 3 posts ] |
Armin
Posted: Mon 21. May 2018 19:59:07 |
Hi all,
is it normal that I cannot connect neither a computer, nor the WiFi module after powering the Spirit? If I would like to have a look into the log file or to change parameters direct after flights and connect the interface when the spirit is already powered, I do not get a connection. If I reconnect power on the spirit, everything works fine, however then the log is deleted. Hott integration works well.
Any ideas?
Thanks, Armin
Posted: Mon 21. May 2018 20:07:27 |
it is normal, if you are using HoTT integration because same port is used for the HoTT, not for communicating with computer or wifi module. To make it work, you have to close the integration in the integration menu as described in the HoTT integration guide. Then everything will work and you will be able to access the log.
Armin
Posted: Tue 22. May 2018 7:18:41 |
Dear Thomas,
thanks for the quick response!
[ 3 posts ] |
Users browsing this forum: No registered users and 16 guests |
