Sakuji wrote:
Tomas
I suggest you include at least the option to pick a longer jst wire for those who are flying helis with tapered tail booms like Goblin 380 or Protos Evo. Because for example for the Evo, one can only make a proper mounting point at the untapered part (parallel to the blade and perpendicular to the shaft) which is already 8 inches/ 20 mm from the boom block then another 5 inches/ 12cm to go down the belly which is the only place you can mount a Spirit specially the Pro.
An option at least.
Awesome, Tomas!
Please, disregard my last suggestion. I don't even care now if no cable is included because of your rationale of why it's a specific length. I'll just custom build my own with no problem at all.
ZeXx86 wrote:
We will offer different lengths of cables. You can also use our JST-Servo adapters to make a different lengths.
In any case we highly recommend making the cable as short as possible. So there is good reason why the length is such. Shorter = better.
Soon we will release guide which will describe optimal mounting conditions for the modules.
We all knew you're at the top of the game. Please, keep it up!
