It is currently Sun 24. Nov 2024 19:24:16
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon 07. May 2018 16:57:56
The newer FW will only show capacity and current data on Hobbywing ESC's 80A and above.
The smaller versions with 25, 40 and 60A are missing this feature! See Manual
PostPosted: Tue 17. Jul 2018 14:05:26
Is this included in latest firmwares? I get the capacity on the ESC screen, but on on Flight Capacity, is the special firmware still needed? My version is the latest - updated this weekend. The radio is DX5e.
PostPosted: Tue 17. Jul 2018 21:51:13
no, you will need unofficial 2.4.4 which can be downloaded in on the forum:
http://www.spirit-system.com/dl/fw/spirit-fw-2.4.4.4df
PostPosted: Wed 18. Jul 2018 12:02:34
Great, it works.
One more question - I had to configure the "I-Motor Shunt" to 143% for the reading to be correct (for both firmwares). I did the calibation while having heli on the bench, with blades dismounted, so no big load (it can run ~20 mins like that). Is this number - 143% - going to work well for real flight conditions or will I need to recalibrate?
Just curious if I can rely on capacity for the first flight.
PostPosted: Wed 18. Jul 2018 17:13:00
No, it will not work.
Capacity measurement with no load (even with blades on) will be very off from real flight since Current measurement is very imprecise.
Only in flight and higher currents the precision is quite good.
PostPosted: Wed 18. Jul 2018 19:06:59
Oh.. then it's going to be a careful flightthen.. I actually wondered if Spirit gets mAh from ESC or only Amps and calculates mAh on it's own. I guess the latter - then right, the Amps is jumping like crazy all the time during tests without blades.
Users browsing this forum: No registered users and 51 guests
