ZeXx86 wrote:
can you share your settings please? You do not have to take a screenshots. It is enough to attach one 4ds file that you can get in the Backup tab.
Then we will see all the settings.
The tail issue could be solved in the Advanced tab, but this depends on your current settings.
I just tried to get 4ds file for you and here's how this goes for me...
I can save my settings but THE ONLY WAY I can find or see the saved file is with model connected to pc and Spirit software open, then choose 'load' under the backup tab in spirit as you would if transferring set up to different model. Any other way than this, it's like the saved file doesn't even exist. When in that screen, I right click the 4ds file to move it, copy it, or share it and I get the results in the attached pic. Can't do anything with it.
