It is currently Sun 24. Nov 2024 15:40:31
PostPosted: Thu 12. Apr 2018 22:12:09
Can i connect and use the Bluetooth module with the micro spirit ?
PostPosted: Thu 12. Apr 2018 22:20:52
yes, you can use any peripheral that is compatible with Spirit units.
You might need just adapters (up to 2x JST-Servo). If you have receiver with a free servo port, you can use this port for powering. And communication cable will be connected by the JST-Servo provided for the USB interface.
PostPosted: Thu 12. Apr 2018 22:29:39
Thanks you are very fast to answer.
I am setting up for a 230S, I read on a post about confit for a tail motor but can’t find the parameters and what I have to do in this situation.
In the software they’re is the 230S preset but not sure what has to change.
PostPosted: Fri 13. Apr 2018 13:42:06
you should configure everything that is in the Setup wizard to make it work correctly.
Users browsing this forum: mainstreet and 50 guests
