It is currently Mon 25. Nov 2024 1:02:33
PostPosted: Thu 29. Mar 2018 22:59:24
i want to use Spirit Aero with Hobbywing 120 v4 Telemetrie with Futaba FX22. Is it only working with Sbus2 or can it also work with Sbus? I pluged the Spirit in Sbus Port of my Receiver and i see no Data.
LG
Flo
PostPosted: Fri 30. Mar 2018 9:00:56
ok, i repluged it to the Sbus2 Slot. But there is still no Telemetry.
I dont know what to do else?
PostPosted: Fri 30. Mar 2018 18:38:20
you will need to use the SBUS2 port always for this purpose.
Is the FrSky integration cable connected to the unit? (not the SBUS Adapter).
PostPosted: Thu 05. Apr 2018 11:23:54
im sorry but it is not working.
I ordered the FrSky Cable. Modified it and pluged it into the SBus2 Port of my Receiver like on the Pictures of the Integration Guide. The normal funktion of the Rudders etc are correct working. In the TX there is 14channel Fastest Mode with active Telemetrie 1s DL. In Settings 1th position slot ROXXY ESC as the Sensor, 6th position slot SBS-01V. The Spirit Unit and the TX are with the newest Updates. In Settings of the Unit there is Telemetrie with Hobbywing v4 selected.
What can i do else? :(
PostPosted: Thu 14. Jun 2018 23:47:07
Hello D,
Still not figure out?
You need Telem uni ESC cable, also to link from ESC to spirit PRO.
Also, In sensor menu, you should pick KONTRONIK esc. I believe you can not pick ROXXY anymore.
And also the sensor menu have specific slot for each sensor device arrangement. So you should try. I think it was slot 7 or 8 that works. Try search and you gonna find a special firmware for that.
Best luck D.
