It is currently Sun 24. Nov 2024 15:47:02
[ 4 posts ] |
rolandk
Posted: Tue 27. Mar 2018 18:42:01 |
I want to use a µSpirit on a Blade 250CFX.
Can anybody help me, how to make the setup of the tail rotor (Rudder endpoint values, how can I prevent tailrotor from turning, when in subtrim mode, is throttle range the same as Blade 230S????).
Thanks in advance for every answer.
With best regards
Roland
Posted: Wed 28. Mar 2018 7:35:03 |
Hello Roland,
yes, first you can start the Setup wizard as usually, then during the process you will see option for Rudder control type where you will have to set the Motor. When configuring Rudder end-points you will simply define travel range for the Rudder ESC with these two values. One value will be for complete stop and other for full throttle.
Once configured it will work just fine.
The upcoming version will be much clearer in that aspect and there are also other improvements for getting also better performance. If you wish, we can share such version right now.
rolandk
Posted: Wed 28. Mar 2018 17:45:21 |
Hello Tomas,
thank You very much for your help.
The ordered µSpirit is announced for tomorrow, so I can use your tips at once.
How can I share the new Version you mentioned?
With best regards
Roland
Posted: Thu 29. Mar 2018 7:24:36 |
Hello Roland,
I will contact you in a private message.
[ 4 posts ] |
Users browsing this forum: mainstreet and 47 guests |
