I guess that recommendation of Luca is for very different FBL. Our FBL is different so it is very normal. You can increase the Gyro gain until you will see any oscillation in fast forward flight or pitch pumps.
Regarding Cyclic, the issue is usually caused by Center of Gravity or servo mechanical center. The center must be configured so that all servo arms are at the center, when you enable Servos/Subtrim (tuning) menu. At the same time there should be 0° between blades. So even with the lowest cyclic gain it should be not there if all is OK.
To find how to configure it perfectly precisely please check this page:
http://manual.spirit-system.com/index.p ... tive_Pitch
