It is currently Sun 24. Nov 2024 15:09:56
PostPosted: Sat 10. Mar 2018 1:22:13
Hi Tomas ! I would like to set my governor rpm at 1200 , but the spirit governor minimum is 1500 , is there a way to set it to 1200 . Thanks
 Post subject: Re: Lower governors rpm
PostPosted: Sat 10. Mar 2018 9:18:32
you can set it without any problem.
The minimum is approximately 750 RPM :)
PostPosted: Sat 10. Mar 2018 13:34:37
I tried many time . I just went back to 1500 .
PostPosted: Sat 10. Mar 2018 18:36:08
I think you are seeing 1500 as Max head speed. But it does not mean you can't set lower. Just set TC to 80% to achieve 1200 RPM. 100% will result in 1500 RPM.
PostPosted: Sat 10. Mar 2018 22:20:35
Thanks Tomas ! For turn on the light .
PostPosted: Sun 11. Mar 2018 22:57:50
You are welcome!
Users browsing this forum: 10x, Bing [Bot], mainstreet and 56 guests
