It is currently Sun 24. Nov 2024 14:57:49
[ 3 posts ] |
ryguy76
Posted: Tue 27. Feb 2018 4:45:25 |
I am finishing up on a new Oxy 4 build and noticed that the boom clamp has a slight seam between the mating pieces. If I place the Spirit in the middle of the boom clamp, I can rock the FBL from side to side slightly due to the high center of the seam. I had used the white foam tape to mount the Spirit and it looked a little off-level to the eye. Is this something that really matters? Does it need to be perfectly level or is this my OCD getting in the way?
Thanks in advance.
Posted: Tue 27. Feb 2018 8:10:56 |
in that case it is better to cut two pieces of the tape and make a kind of rails under the unit. so that in the middle there is nothing. More precisely the unit is mounted, more precisely it will fly.
ryguy76
Posted: Tue 27. Feb 2018 21:08:12 |
Thanks Tomas.
[ 3 posts ] |
Users browsing this forum: No registered users and 50 guests |
