It is currently Sun 24. Nov 2024 13:59:51
 Post subject: Jeti Vario meter
PostPosted: Sat 17. Feb 2018 21:00:39
I'm trying to setup a hard deck for rescue, so I need a vario meter.
Here is one from Jeti: http://shop.jetiusa.com/Jeti-Telemetry- ... titmv2.htm
It seems it has to be connected with either EXT1 or EXT2, in this case, I have to sacrifice either telemetry or Jeti integration.
I'm using Spirit pro, can I connect the Vario meter to the Spirit instead of receiver?
 Post subject: Re: Jeti Vario meter
PostPosted: Sat 17. Feb 2018 21:08:20
if you are using REX receiver, you can connect it all together.
EXT1 can be used for Spirit unit, EXT2 for the sensor.
PostPosted: Sat 17. Feb 2018 23:00:19
Ok, I got it, going to buy a REX.
Thanks a lot! You are always so helpful.
