It is currently Fri 22. Nov 2024 23:19:16
Post new topic Reply to topic  [ 291 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 30  Next
 Post subject: Re: GPS?
PostPosted: Sun 28. Jan 2018 9:12:04
ZeXx86 wrote:
Progress is very good, since the most important stuff is working already.
The module itself require still more tuning to obtain the best signal and so we are cooperating with manufacturer of the chip.
It takes a lot of time, since it is over two continents. After that operation we believe we will be able to supply more testing pilots with the modules.
Great is that the module itself can be updated so firmware everywhere can be enhanced over time.
Great to hear that the hardware is perfecting...
Since as we know there were couple of similar products which didn't seem to be very successful.
Difficult setup, sensitive to vibration, not allowing acrobatic movement or too expensive.
hope the new one will overcome all of those soon.
PostPosted: Mon 29. Jan 2018 8:43:54
Right now the hardware is basically ready and is tuned well.
I can also reveal that it is not sensitive to any kind of vibration, can be used with any flight style and can work out of the box with no configuration required.
With configuration you can simply enable features you wish to use.
PostPosted: Mon 29. Jan 2018 14:29:54
This is excellent news Tomas, thanks for the update and looking forward to more soon. :D
Kevin
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
PostPosted: Mon 29. Jan 2018 16:49:06
Perfect news!
I am looking forward to it!
As always, very good work by Tomas!
Greetings from Gernot
PostPosted: Mon 29. Jan 2018 22:38:35
Finally some good news! I will be checking the site every day when it will become available for preorder.!
PostPosted: Wed 31. Jan 2018 22:24:03
Truly awesome news Tomas and Team!
Thanks for sharing the information you can share at this time, exciting times for all, this new GPS will be a game changer for many!
Congratulations on all your many successes so far, as well as the new GPS, with all of it's configurable features I am sure will be one of the most sought after units ever! Keep up the great work, it is so very very much appreciated!
Thanks, Dave :D
PostPosted: Thu 01. Feb 2018 10:37:06
Congratulations indeed.
I'm curious on how it will connect to the Spirit. Will we need to sacrifice ESC telemetry or transmitter integration? Or will it connect on AUX2 or Channel 0?
PostPosted: Fri 02. Feb 2018 15:30:04
This is great news, Tomas! It's what we've been waiting for!
What are the typical uses of this upgrade you have developed so far?
I can imagine it can be used for heli scale models and of course planes/ gliders. How about for heli 3D fliers? Does it contain a minimum height limiter similar to the soft deck/ hard deck of Skookum?
Thanks!
PostPosted: Mon 19. Feb 2018 22:18:52
I have been watching this topic and waiting to pull the trigger on a Spirit Pro.
But waiting for GPS news before buying.
Can you update us a time line and features that will be available ?
PostPosted: Wed 21. Feb 2018 19:13:50
We have changed few parts inside the module to achieve better performance. Now we are certain that the module is built from the best available parts for the purpose.
Firmware testing is going well, some features are fully tested now and ready for usage.
Enclosures are nearly ready as well.
