It is currently Sun 24. Nov 2024 13:06:12
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Nitro gov needs work
PostPosted: Sun 21. Jan 2018 10:16:28
HI i would also be interested in the beta up date. i have 2x 700 nitros that i could not get the spirit gov to work properly on and have changed to the multigov pro.
A firend at my flying feild has the same issues and is also changing to an external gov. so we would both be keen to test the update
PostPosted: Sun 21. Jan 2018 15:50:35
Thank you for the interest. I will contact you as soon as it will be possible.
The throttle curve is quite normal V, which is very interesting that it actually holds better. It look like the governor must acting in the opposite way :-B
To make it work at least on par or better as with V curve you will need at least to increase Governor Response, while no Holding Performance is needed.
That is very interesting and shows that something is really not correct.
PostPosted: Mon 22. Jan 2018 8:27:19
showmeflyer: That is fortunately OK. If direction of the throttle is reversed in a proper direction then it is supposed to work.
PostPosted: Mon 22. Jan 2018 20:16:16
I finally have the governor working on my nitro. Flew 9 tanks in a row with no bogging and very little over speeding. All 3 head speeds lock on instantly. This is as good or maybe better than the multigov I had been using. Hope to get my gasser to work this well .
Thanks for the help.
PostPosted: Tue 23. Jan 2018 3:27:06
Hi, do you have telemetry ? If so, can you post a flight log please.
PostPosted: Tue 23. Jan 2018 7:14:08
showmeflyer what did you do to get it working.
PostPosted: Wed 24. Jan 2018 0:03:19
I made several changes since I was planning on going back to the Multigov I changed the magnets back to having only one active instead of both active. Decided to give it one more chance so after trying several different combinations I ended up with response set to 9 and hold to 3. This made my three different requested head speeds close but still some over speeding but got rid of most of the bogging. Response at 8 and hold at 3 seemed to work a bit better at lower head speeds. The last change I made was to open my mid range needle about 3 clicks and the over speed was less. Opened another 4 clicks and it works great. I turned the gov off and carb settings seem to be close enough on regular throttle curves for me. I had around 20 gallons thru this engine with my mid needle set 7 clicks leaner than now so I don't think I was running to lean.
PostPosted: Thu 25. Jan 2018 4:34:01
7 clicks ? I suspect it is running so rich that it is sluggish to accelerate and thus the overspeeding is avoided ?
PostPosted: Thu 25. Jan 2018 8:39:09
Very well, thank you for the message!
We also recommend to set engine at the rich side, otherwise there is tendency for overspeeding even with flat TC. This is pretty bad for governor.
PostPosted: Thu 25. Jan 2018 8:41:27
I'm sure every case is a little different. In my case with the gov on and holding performance maxed out at 6, the heli bogged in loops where as it did not bog in loops when using v-curves without any needle setting changes. So the engine was obviously capable of powering through the loops set to how it was. There's a video of me flying at IRCHA with the governor enabled and it sounds like the engine wants to die the entire time.
Users browsing this forum: No registered users and 87 guests
