It is currently Sun 24. Nov 2024 13:05:16
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
PostPosted: Tue 09. Jan 2018 11:07:16
Hello Tomas!
Is it possible to change only one bank at a time with the real-time tuning, eg B.P: Style, or would all banks that have been changed during the flight remain stored in the Spirit?
Assigned P: Style and changed the style for all three banks during a flight. After I landed and looked into the software (Jeti Sender), the value was changed for only one bank, for the other banks the old values were inside again ?
Please explain the problem?
Greetings Gernot
Greetings from Gernot
 Post subject: Re: Real Time Tuning
PostPosted: Tue 09. Jan 2018 11:14:00
the value is changed for all banks when flying. So whatever bank is selected, the value is overwritten by specified value from assigned channel.
But if you will not save it and switch to other bank, it will be not saved.
For this reason you can see it only in the last bank. But even there it is not saved - it is as when you will set something in the software and close it without saving.
PostPosted: Tue 09. Jan 2018 11:30:47
If I understood correctly, then if I change a value in Bank 2 (highest speed) with real-time tuning, I have to land with this bank, without switching over and then saving and changing, landing and saving the next bank on the next flight ?
Is it correct that way?
PostPosted: Tue 09. Jan 2018 11:33:28
Yes, in this way it is possible to change the value in each bank to stay there permanently.
Then you can disable realtime tuning and these values will be still there.
PostPosted: Tue 09. Jan 2018 11:44:23
ok I understand.
1) In the future (next update), will it be possible to switch banks from the transmitter during programming via the software?
2) Is the bench comparison only possible in the PC software or is it also possible with the Jeti controller?
PostPosted: Tue 09. Jan 2018 11:54:00
1) This is already possible for very long time with all integrations.
2) At the moment yes. But in future it should be available for transmitter integration too.
PostPosted: Tue 09. Jan 2018 12:03:55
I think the question 1) you have misunderstood, so far you can not switch during the active PC software and transmitter integration with the transmitter banks, just in the software? Or did I miss something?
PostPosted: Tue 09. Jan 2018 12:08:25
You can change banks, but in the software/integration if software/integration is opened.
Changing by assigned channel is temporarily disabled.
In the new software changing banks by assigned channel will work automatically.
PostPosted: Tue 09. Jan 2018 12:19:44
Super, I'm glad that we at the airfield where you work with the integration a great relief, because you do not always have to jump back to the bank switching in the menu!
Do you already know when this will happen?
PostPosted: Tue 09. Jan 2018 12:23:08
I am sorry, but I dont understand the question :(
Users browsing this forum: No registered users and 85 guests
