It is currently Sun 24. Nov 2024 12:39:06
PostPosted: Tue 02. Jan 2018 21:04:43
Hello
I guess my last post is closed ( solved).
after all settings on my Futaba T8FG like your "set up guide for Futaba" : gain giro at 60%
On diagnostic :
Giro / normal condition 68%
Giro / SH button ON / 63% ("Rescue" appears)
Is it the right setting ? why not 60% for nc and -60% for rescue ?
Thank for you help :)
PostPosted: Thu 04. Jan 2018 8:29:18
Hello!
It looks to be good. There could be little bit difference between % if channel center is not exact.
For Gyro channel you can fix it by using a Subtrim for Gyro channel in your radio until you will obtain same percentages in both directions.
If you can see + Rescue, then it mean that you have entered negative gyro gain. This is correct behavior. But the actual Gyro Gain for the unit will be 60%. So basically all is correct and even with the gain difference you can fly now.
S-BUS connection is little bit more precise, because it is tailored exactly for Futaba and data are sent digitally.
But it is small difference and PWM will work as well.
PostPosted: Thu 04. Jan 2018 11:41:23
As you say it's simpler in S BUS, I connected a receiver FRSKY TFR8 SB.
Set up ok with giro gain + 60% and -60% in RESCUE.
But a question?
Which channel of the TFR8 receiver should I connect the optional cable from AUX1 of the spirit module?
(I already connected the ESC on channel 3 of the receiver S BUS.)
Many thanks
PostPosted: Thu 04. Jan 2018 12:27:36
you can use any other channel.
PostPosted: Fri 05. Jan 2018 9:14:13
Hello
Thank you for your availability
Users browsing this forum: Bing [Bot] and 77 guests
