It is currently Sun 24. Nov 2024 12:51:32
PostPosted: Mon 01. Jan 2018 12:53:07
After installation Spirit Pro on my TREX 500 / TX Futaba T8FG / Rx Futaba R617FS , when I check "channels" with Spirit Settings v2.4.3 on my computer , the screen is different with your of Spirit System Manual !
Indicator of Throttle is green on a half and i have "unassigned" for channel ?
Indicator of Pitch is green on 1/4 ?
Is this normal ?
Many thanks for your product and Happy New Year 2018
File comment: view FUTABA T8FG at the same time
 Post subject: Re: Set up SPIRIT PRO
PostPosted: Mon 01. Jan 2018 16:05:49
you are using PWM connection which needs little bit more adjustments in the radio.
You may need to modify Travel Adjust to obtain +/- 100% on all channels.
Is the Pitch channel moving when you are moving with Pitch stick?
Throttle is unassigned, because it is not transffered by the cables. So only receiver is seeing the value. Unit does not care about throttle with PWM connection since the ESC is connected to the receiver.
Happy New Year too!
PostPosted: Mon 01. Jan 2018 20:57:43
Hello
Many thanks for the quick answer !
The Pitch channel is moving when I am moving with Pitch stick / see 2 pictures
More 2 pictures on diagnostic with Pitch stick on 100% and more Pitch stick on 0%
File comment: diagnostic when pitch stick 100%
File comment: Futaba Pitch stick 100 %
File comment: Pitch stick 100%
PostPosted: Mon 01. Jan 2018 21:01:01
Hello
second view
File comment: dignostic with pitch stick on 0%
PostPosted: Tue 02. Jan 2018 8:27:54
Thank you!
Please check in your radio that the pitch channel is going all the way from -100 to 100%. There could be some curve configured in.
The easiest way to verify it is to check SERVO menu in the radio. Then move with the Pitch stick.
Also note, that each power up, the unit is detecting centering signal. If aileron, elevator or rudder sticks are not in the center, then the center will be off for the pitch channel.
But still there is issue with the small range, so I think that it is all caused by some pitch curve in the radio.
PostPosted: Tue 02. Jan 2018 9:26:18
OK
I change the configuration in my FUTABA / Model TYPE / SWASH H-1 and not SWASH HR3
Now on "SERVO" I have : 100% and -100% for pitch stick :D
I continue my set up
Many Thanks ;)
PostPosted: Tue 02. Jan 2018 9:43:18
Perfect, you are welcome!
PostPosted: Tue 02. Jan 2018 10:45:23
last thing before to fly
after all settings on my Futaba T8FG like your "set up guide for Futaba"
On diagnostic :
Giro / normal condition 68%
Giro / SH button ON / 63% ("Rescue" appears)
Is it the right setting ? why not 60% and -60% for rescue ?
Users browsing this forum: No registered users and 89 guests
