It is currently Fri 22. Nov 2024 2:06:57
 Post subject: Aileron Differential
PostPosted: Sun 10. Dec 2017 23:11:13
Does the aileron differential parameter in the Spirit work like conventional differential and decrease the downward movement of the ailerons? The manual for the Ultimate suggests 40 degrees up and 35 degrees down at full throws. How do I achieve this in the Spirit?
 Post subject: Re: Aileron Differential
PostPosted: Mon 11. Dec 2017 10:53:23
Yes, it is working in this way. You can just set it at 87% to achieve what you wish.
PostPosted: Mon 11. Dec 2017 11:29:21
Thank you Tomas!! Best support as always!
Sent from my iPhone using Tapatalk Pro
PostPosted: Mon 11. Dec 2017 19:27:05
Tomas; the 0% aileron differential default setting means its off? I would have guessed to set about 11% to reduce throw from 40 to 35 degrees. Just so I dont mess things up!
PostPosted: Mon 11. Dec 2017 20:49:41
It is as I suspected, I set aileron diff at 13%. Looke about right on the bench
PostPosted: Tue 12. Dec 2017 8:19:41
Oops, yes, you are perfectly right.
Just calculator was giving incorrect value (opposite) :)
You can calculate it in this way:
value = (1 - (35 / 40)) * 100
Users browsing this forum: No registered users and 8 guests
