It is currently Sun 24. Nov 2024 11:27:32
[ 7 posts ] |
GoblinShefford
Posted: Wed 18. Oct 2017 0:27:18 |
i have a spirit pro + x8r + taranis ... connect with s-bus with straigt cable all work good and today i try to open my heli and i have initialisation problem... the light slow blink red ... after 30-45 sec the system initialise swash move ok and another 1 min later all control stop ... i wait another 10 sec all was back, after 30 sec all control stop ... i try to connect in usb i see the control no log error and after 30-45 sec the connection usb was lost and i need to remove power and restart all for the same result ... i have try to reset the unity and same problem ... my spirit was broke ? i dont have crash or nothing special with it .. help will be aapreciated
Posted: Wed 18. Oct 2017 9:39:51 |
was there any wiring changes prior this problem? Anything that changed could cause the problem. Can you disconnect all servos and everything that is not necessary (all except ESC/BEC)?
GoblinShefford
Posted: Wed 18. Oct 2017 12:25:49 |
i have try what you said and same thing slow red blink long time to initialise,make error ( head jumping few time) can connect to the pc with usb but after 10-20 sec lost connection a i need to reboot all for work again 10-20 sec .. i have try a link usb cable from my friend and same problem ... the only thing that change in wire it's the day before i make error and i plug the bec in aux2 insted of aux1 but in the manual it's not suppose to damage the unit i could not figure the problem :/ it's seem to be with the sys port
Last edited by GoblinShefford on Thu 19. Oct 2017 2:17:50, edited 1 time in total.
GoblinShefford
Posted: Thu 19. Oct 2017 2:15:05 |
i have try other thing .... ok lets me describe better than previous ...
i plug my batt in the bec... the spiritpro slow red blink take time to initalise ... i have a bec talon 90 he make only 6 bip (detect my 6s batt) and that's all ... no other sound same as habitually .... after few other second the spirit initialise ... i can connect in usb and all servo work ... if i play all the time with the cyclic the servo and usb connection dont stop working ... but when i dont touch Nothing 2-3 sec. the spirit pro stop work but the light always red ... if i play with the cyclic Nothing work ... but if i continu to play with cyclic after few second the spirit pro respond i can reconnect with usb and servo work ... when i never disconnect the spiritpro i can see in log file
00:00 calibration finished Main loop hang occured
00:10 Main loop hang occured 00:20 cyclic ring activated Main loop hang occured 00:30 cyclic ring activated Recivied frame was corupted 00:40 cyclic ring activated 00:50 cyclic ring activated Main loop hang occured 01:00 Main loop hang occured 01:10 cyclic ring activated Main loop hang occured
Posted: Thu 19. Oct 2017 7:38:46 |
Thank you for your info. Unfortunately Main Loop Hand event is indicating some very important problem. If nothing is in the unit except USB interface and BEC, then I fear something happened to unit. Plugging power to AUX2 is not a problem. Only if red and black wires are swapped. Do you think you can send the unit to us? We will fix it in one day and find what happened.
GoblinShefford
Posted: Thu 19. Oct 2017 13:16:36 |
to this adress ?
Spirit System Tomas Jedrzejek K Olsine 28 73514 Orlova-Lutyne Czech Republic
Posted: Thu 19. Oct 2017 13:31:48 |
Yes, please.
Where are you from? If it is outside of EU, please declare package value under 25 USD to allow easy customs.
[ 7 posts ] |
Users browsing this forum: No registered users and 16 guests |
