It is currently Sun 24. Nov 2024 11:47:27
 Post subject: slow pumping response
PostPosted: Sat 30. Sep 2017 13:36:37
Hi
One of my heli's flip response is quite fast but when I do pitch pumping response is sluggish.
blade length = 360mm (480 class)
collective angle = 13 degree
cyclic angle = 8 degree
RPM = around 2800~3400 (?) anyway, increasing rpm didn't help
flight style = 6
feel like internal expo for collective pumping... but not for cyclic movement.
Which parameter should I change?
PostPosted: Sat 30. Sep 2017 18:32:32
unfortunately there is no parameter that could affect the collective other than the Collective Pitch Range.
If you feel a delay, then it could be caused by a problem with axial ball bearings in the rotor head.
Then it will cause delayed response and also other unwanted phenomenons. But firstly you can notice slow collective response.
So I recommend to check the rotor head.
PostPosted: Tue 10. Oct 2017 11:20:15
It was my bad.
Collective was 10 deg. I've changed it to 13 deg. and it feels alright.
I will reduce cyclic from 8 to 6 deg.
I like the rolling. it's quite smooth compare to *BAR.
KH
PostPosted: Tue 10. Oct 2017 11:32:32
Great!
If you mean Cyclic Ring, then even 8° could be too low.
This limit should be at least around 9°.
PostPosted: Tue 10. Oct 2017 11:51:29
I meant cyclic pitch angle. I think I set it as 8 deg. during PC setup. (May be I mixed up with *BAR - I remember it was 6 deg. in *BAR)
Cyclic ring is 11 deg. Anyway, it feels alright so I will leave as it is for now.
Thank you for advice.
Regards,
KH
PostPosted: Wed 11. Oct 2017 21:47:12
What do you mean with "Cyclic pitch angle" being different to "Cyclic ring" degrees?
PostPosted: Thu 12. Oct 2017 5:15:31
Please, refer this physical ring story for mode 2. Modern FBL uses digital limits. Instead of real ring.
https://rc.runryder.com/helicopter/t217916p1/
PostPosted: Thu 12. Oct 2017 7:11:27
RedJacket: Indeed, but our unit has electronic Cyclic Ring :)
Coco66: I think he meant Cyclic Ring - Aileron/Elevator Range parameter.
Users browsing this forum: Bing [Bot] and 46 guests
