It is currently Sun 24. Nov 2024 9:29:12
PostPosted: Thu 21. Sep 2017 17:54:58
I have the spirit pro with a castle ice2 HV 160.
I have a hobby wing rpm sensor hooked up to the spirit with red black going to the rudder port and the white wire going to the pitch pin.
I'm using the spirit gov
Can I use a y cable with the setup I have off the rudder port for adding the spektrum SPM4649T telemetry receiver and using the jeti integration cables brown and red wires to that y cable?
And take the orange wire and add it to ail pin
I have the wifi module getting power from channel 0 but I can unhook my wifi module now since I got the integration and use that to power the hobbywing rpm sensor.
Any feedback is appreciated
PostPosted: Thu 21. Sep 2017 18:28:25
yes, you can use Y-cable with no problem. It is used just for powering.
You can also use CH0 port for this purpose.
Or you can use SPM4649T and create your own Jeti integration cable from this. Other lead (female) can then be used for powering the RPM sensor. So you will not need Y-cable at all.
PostPosted: Thu 21. Sep 2017 18:30:55
Thank you...
Users browsing this forum: No registered users and 43 guests
