1) Well, I've checked every pre-registered items in sensor menu.
Temperature
Voltage
Current
rpm sensor
Altitude
GPS
Servo sensor
Temp-F1713
GPS-F1675
Vario-F1712
Vario-F1672
Curr. F1678
Kontronik ESC
Castle TL0
JetCat V10
PowerBox
None of them works.
Tried firmware version 1.2 to 3.0E (there was no "ROXXY ESC" in pre-registered item)
All the firmwares I've tested with 18sz.
http://www.ripmax.com/Futaba_Upgrade.aspx?UGID=T18SZBut it seems that 14SG has one
18sz:
https://youtu.be/B0_WDpsd_Sk?t=17614sg:
https://youtu.be/85mOP9es7_c?t=48So the manual should be updated.
http://manual.spirit-system.com/index.php?title=Futaba_Telemetry2) I've tried to register "Spirit Pro" as a sensor using SBUS2 input wire to T18SZ
Not detected.
3) I found Jlog32 had similar problem but it can ID itself as "ROXXY ESC" to 18SZ.
https://www.helifreak.com/showthread.php?t=767437Any comment?
KH.
