Campbell wrote:
I'm using the HW v4 esc, dx8 g2 and spirit pro. Using the intergration I'm getting the wrong reading for rpm, and no reading for rx voltage.
This worked for a bit but in now having problems. I have been working through this with Tomas but we don't seem to be able to resolve it.
Has anyone else experienced this issue?
I have the rpm sorted now
The answer was in someone else's question, basically. I have been setting the gear ratio up in the tx, not the spirit.
I was under the assumption that you only did it in the unit of you were using the spirit gov.
Sooo, I set my tx to poles inhibited, ge a ratio 1.00:1. Then activated gov in spirit, set the divider to 5 (10p) and set my gear ratio. Then turned gov of to find my settings stayed there.
Spooled the heli up and bingo, it works a treat.
