It is currently Fri 22. Nov 2024 5:43:48
 Post subject: Mah consumption
PostPosted: Thu 31. Aug 2017 9:02:20
Is there a way to get the mah consumption telemetry with the spirit pro, HW 120a v4 using the spektrum integration?
 Post subject: Re: Mah consumption
PostPosted: Thu 31. Aug 2017 9:10:30
Yes, it is working out of the box with this telemetry as described in these guides:
http://manual.spirit-system.com/index.p ... g_the_data
http://manual.spirit-system.com/index.p ... metry_data
PostPosted: Thu 31. Aug 2017 10:27:00
Ah, I was looking in the wrong place.
Thank you
PostPosted: Thu 31. Aug 2017 15:48:00
You are welcome ;)
PostPosted: Fri 01. Sep 2017 6:09:29
Might be a silly question, but if it reads say 15.6c, does that read 1560mah?
PostPosted: Fri 01. Sep 2017 9:38:31
According example from the guide: 1234mAh = 123.4C
So 15.6C should be 156mah.
PostPosted: Fri 01. Sep 2017 19:49:22
Perfect.
Thanks again for the top notch support.
Users browsing this forum: Bing [Bot] and 11 guests
