Hey
I'm still struggling... No throttle signal detected by the ESC
This is how it is connected atm:
SYS -> Telemetry Port (Graupner GR-18 Channel 9)
CH0 -> not used
CH1 -> Servo
CH2 -> Servo
CH3 -> Servo
CH4 -> Servo
AUX2 -> External BEC only red/black
AUX1 -> Throttle Port to HW ESC (removed middle red wire)
RUD -> SUMD Port RX (Graupner GR-18 Channel 6) according to wiring described in
http://manual.spirit-system.com/index.p ... gration/enELE/PIT/AIL -> not used
Telemetry from ESC is working from my transmitter, Servos move properly, except the Hobbywing ESC never gets a signal from the Spirit Pro. When connected to a computer, i see the throttle channel and its showing properly the throttle value from 0 - 100%. I also connected a servo to AUX1 and its moving properly when i change throttle (servo obv. also has the red wire connected in contrast to the HW ESC).
The HW ESC always beeps, signaling there is no throttle signal.
I tried different frequencies (60, 120, 200Hz), disabled/enabled the governor in spirit but it's always the same result. What am I missing here?
I would like to use the governor in the spirit. Is the telemetry channel a valid replacement for the rpm out of the ESC?
Oli
