It is currently Fri 22. Nov 2024 2:23:45
 Post subject: GYRO NORMAL RATE+STABY
PostPosted: Fri 11. Aug 2017 10:51:41
Hi, I use two banks:
In the first I do not have the staby and the gyro (adjustable by tx with knob) has the HL-0-Normal function.
In the second I have staby, but the gyro only has HL-0-HL + Staby functions.
Is it possible in bank 2 to have the HL-0-Normal + Staby function? I not want HL with Staby.
PostPosted: Fri 25. Aug 2017 17:59:30
Hi, same replay?
PostPosted: Fri 25. Aug 2017 19:38:49
sorry for late reply.
You can configure it in this way:
Bank 0:
Stabi/Function - Disabled
Bank 2:
Stabi/Function - Stabilisation (Normal or Acro)
For both Banks set Global Gain to a negative value.
Then there will be only Normal mode or Stabilisation. With Bank switch you can change it anytime.
PostPosted: Fri 25. Aug 2017 19:57:45
Thanks, I try :)
PostPosted: Sat 26. Aug 2017 13:22:54
Hi I set general gain with negative value for both banks, but the situation is non changed, see screenshot.
In this situation I need the Normal+Staby not Head-look+Staby.
Is possible? Thanks
PostPosted: Sat 26. Aug 2017 16:14:44
Ah, this is not possible. Otherwise stabilisation mode will not work. It would not hold required attitude.
So then Stabilisation mode will have no meaning in this case.
PostPosted: Sat 26. Aug 2017 18:06:33
Ok, many thanks.
PostPosted: Sat 26. Aug 2017 18:42:02
You are welcome.
But you can still enable Normal mode (without active Stabilisation). This will make a different behavior.
Users browsing this forum: No registered users and 13 guests
