It is currently Sun 24. Nov 2024 9:48:54
PostPosted: Fri 18. Aug 2017 13:36:32
Are this two connectors the same? Or is there some internal wiring thats different? So can i use the spektrum adaptor that i already have and use it for the HW telemtry cable?
PostPosted: Fri 18. Aug 2017 13:39:28
They are not same.
You can make Telem UNI from Spektrum adapter by unplugging/cutting red wires (ideally from both connectors).
Then it will work. Without this modification it can cause a big problems.
PostPosted: Fri 18. Aug 2017 21:44:30
So just disconnect the red wires from both ends of the sat adaptor?
PostPosted: Fri 18. Aug 2017 22:01:54
yes
PostPosted: Sat 19. Aug 2017 16:15:49
I made my own this way. Used my crimp tool to crimp regular servo pins onto one end of the sat cable. The unused + wire was folded back and covered with heatshrink.
If using orange-black-grey sat cable the orange is + and needs to be removed. Grey is signal and black is -
Users browsing this forum: No registered users and 49 guests
