It is currently Sun 24. Nov 2024 12:47:15
 Post subject: Stabi function channel
PostPosted: Fri 18. Aug 2017 18:33:18
I have banks assigned as such 0 = normal rescue, 1= normal stabi, 2= acro stabi.
Using channel 8 assigned to Stabi Function.
In the diagnostic screen I see when I activate channel 8 I see the gyro switch from head lock to head lock rescue. This works fine from any of the 3 banks. But if I'm in bank 1 or 2 I don't see the Stabi function on the gyro channel. Is this correct or do I still need to program another mix so it shows this. I don't want to use Neg gyro gain I want to assign Pos gain to all three I.U. s.
PostPosted: Fri 18. Aug 2017 18:45:51
When software is connected, your radio will not change banks. Banks can be changed only by combo box in the software.
So please make sure that you are in the right bank when trying it.
PostPosted: Fri 18. Aug 2017 19:27:23
So in order to see if Bank 1 or 2 is assigned correctly on the Diagnostic page I need to change it
in the Active Bank box at the bottom. It should then tell me Headlock Stabi. on the gyro channel. Correct ?
PostPosted: Fri 18. Aug 2017 19:36:01
Yes, exactly.
Or you can close the software and try to observe behavior of the swashplate.
But this is not as easy.
PostPosted: Fri 18. Aug 2017 19:51:57
OK thanks
PostPosted: Fri 18. Aug 2017 23:08:29
If I understand the manual correctly if you use the Stabi Function in channel assignment then you can't use the Neg Gyro Gain method. So you can't use a combination of both ?
Users browsing this forum: No registered users and 79 guests
