It is currently Sun 24. Nov 2024 18:20:21
[ 4 posts ] |
Malc1
Posted: Fri 18. Aug 2017 11:31:12 |
All looks to be correctly set up ok with telemetry on my Tribunus ESC, Jeti DS16 Tx and Spirit Pro.
It seems that I am unable to view battery capacity or current parameters on the system. These are just at zero all the time.
Battery voltage and ESC temperature is displayed ok as is BEC voltage, RPM and vibes. I've tried contacting Scorpion but they say that they have not tested the ESC with the Spirit Unit and can't help at this time. Another user of the Tribunus ESC but with a VBar Nero is confirming that it all works with his set up.
Any ideas please?
Posted: Fri 18. Aug 2017 11:38:38 |
Are you testing it during flight? On the ground you will not see very likely usable values. The ESC require load to measure these values.
Malc1
Posted: Fri 18. Aug 2017 12:43:16 |
Tested on the bench with motor running. No readings of any sort on these parameters what so ever.
Posted: Fri 18. Aug 2017 13:01:02 |
Nearly no ESC will give you a current/capacity reading without a load. So very likely all is correct.
[ 4 posts ] |
