It is currently Sun 24. Nov 2024 22:18:27
PostPosted: Thu 17. Aug 2017 22:21:09
I am trying to set up a new model using a Spirit Pro and Jeti DS16 Transmitter.
Basic set up has been done including the right directions for the cyclic servos.
These all move correctly in all modes except throttle hold.
When throttle hold is operated I do not have any pitch movement at all until hold is released then all is OK. Reduced Cyclic movement for all three servos is seen.
I can see the channel output bar moving OK on the transmitter and correctly in the Spirit software.
The pitch curve in throttle hold is at 0 - 100%.
Correct servo movement on the model is also seen when in the ' Servo Travel Correction' tab in software with throttle hold operated.
Maybe something missed somewhere but any ideas please?
PostPosted: Thu 17. Aug 2017 22:26:04
If you can see pitch movement all the time in the Diagnostic tab, then it is very likely that you have just activated Rescue mode.
This will be also visible in the Diagnostic tab.
Set Gyro Gain in all flight modes (including Hold) to a positive value and then it will be fine.
PostPosted: Thu 17. Aug 2017 22:44:27
Gyro gain was set at 0% in throttle hold mode. :roll:
Now at 65% and now have full pitch movement in all modes.
Not sure if Rescue is correct but will look at that later.
Superb support and a very fast response.
Thanks.
Users browsing this forum: No registered users and 29 guests
