It is currently Mon 25. Nov 2024 17:36:46
 Post subject: Kosmik Telemetrie
PostPosted: Tue 08. Aug 2017 17:19:54
Hello Tomas!
The telemetry with Cosmic and Jeti shows the correct values, but the mAh blink and set more often!
Where can the error be?
Greetings, Gernot
Greetings from Gernot
 Post subject: Re: Kosmik Telemetrie
PostPosted: Tue 08. Aug 2017 18:24:39
this is OK, the only difference is that some telemetry values are updated more frequently and some less frequently.
For example Capacity and Temperature are updated less frequently, because there will be never fast change. This is because EX Bus line can be overloaded so in this way we can add also next things in the future.
PostPosted: Tue 08. Aug 2017 22:04:44
You can change this? Especially with the mAh display it is very disturbing. At temperature or V or A it would not matter. If it with the capacity during an alarm is exposed then the alarm does not come.
PostPosted: Tue 08. Aug 2017 22:09:07
In the upcoming update it will be fixed. Thank you!
PostPosted: Thu 10. Aug 2017 18:40:47
Hello Tomas.Wann comes the update, so the capacity indicator stops or flashes? I would now have to buy no J Log! Please ask for short info whether the problem is to be solved at short notice?
PostPosted: Thu 10. Aug 2017 18:42:31
Yes, it will be solved in the firmware that will be released in a few days.
PostPosted: Thu 10. Aug 2017 18:46:43
Thank you
