It is currently Fri 22. Nov 2024 12:04:22
PostPosted: Mon 07. Aug 2017 12:24:50
I think that some of the parameters at advaned tab are somehow basic settings.
For example;
Geometry tuning - basic setting
Collective Direction - basic setting
These should be in servos tab imho.
Cyclic D gain can be added to advanced tab.
Thanks..
PostPosted: Mon 07. Aug 2017 12:33:14
thank you for suggestion.
These parameters are in advanced tab, because normally you should not access them anymore.
The basic configuration is done through the Setup wizard where these parameters are configured in a proper way (since it is dependent in which step you will set it). So you should only access them (once the initial setup is done) if you feel to be more advanced and you understand what it is doing when you change it not according the previous configuration from the wizard.
These parameters will not change after the setup, so normally you do not have to change them.
PostPosted: Mon 07. Aug 2017 14:00:46
Thanks for your reply. I did not ever use the wizard, because it's already very easy by tabs :roll:
Is there any parameter that sets the stopping behavior of the cyclic movements ?
PostPosted: Mon 07. Aug 2017 14:18:45
Yes, this is Elevator Filter and Cyclic Feed Forward.
Usually aileron issues are only in case of wrong settings or very slow servos, so elevator filter is often enough.
