It is currently Mon 25. Nov 2024 0:10:46
PostPosted: Mon 19. Jun 2017 20:18:00
Hello!
My Spirit software does not start anymore ...?
I can only open the demo mode.
The spirit works normally The software I have already installed!
My other Spirit FBL work!
Thanks!
PostPosted: Mon 19. Jun 2017 20:24:47
Make sure the plug to the FBL is fully in... that's what happens when the PC Software does not "see" the unit...
PostPosted: Mon 19. Jun 2017 21:16:18
Alternatively the USB interface was damaged, please check that the wires are good, especially on the PCB.
Some users are pulling it by cables, which is not making them happy :)
Or do you remember what was the last operation when it worked? Did you reconfigured something?
PostPosted: Tue 20. Jun 2017 18:17:31
Tomas, you're right!
I have the cable re-soldered and the software works again perfectly!
Thanks!!!
Greeting Frank
PostPosted: Tue 20. Jun 2017 21:18:11
Good job!
Thank you for the message.
PostPosted: Wed 21. Jun 2017 18:01:10
Hi!
I do not know what's going on, now it is not again. Again goes only the demo mode ...?
PostPosted: Wed 21. Jun 2017 20:41:16
maybe the problem is again there.
From the photo I can see that there is some wire which is nearly touching other one.
Maybe it shorted there.
PostPosted: Thu 22. Jun 2017 17:48:00
Sorry Tomas,
the second photo is after the new soldering.
No cables or contacts touch on the photo.
Another idea?
PostPosted: Thu 22. Jun 2017 18:07:42
Are you sure that you have not enabled for example Kontronik telemetry? This would disable USB communication as described in the Telemetry window.
PostPosted: Thu 22. Jun 2017 18:23:21
Tomas, this is another post...!?
Users browsing this forum: No registered users and 49 guests
