It is currently Sun 24. Nov 2024 19:53:56
[ 5 posts ] |
DHavreluck
Posted: Sat 17. Jun 2017 3:29:15 |
I just got my Spirit Pro and I'm new to electric heli's. After I purchased the Spirit FBL I bought and built an Align Trex 470LM. Everything appears as expected, I have only hovered a few times, stabilization seems flawless. and working nicely but I can't get the ESC to calibrate with SpiritPro. ESC will calibrate with no problem directly with a Spektrum AR8000 and a AR7700 but not with Spirit Pro with AR7700. There must be something about the Spirit that won't allow calibration. I can fly the heli the only problem is the throttle does not engage until 51% stick. For now throttle and pitch curves are linear (0,25,50,75,100). Throttle channel is not reversed. Diagnostic tab under channel input appears correct ( 0-100% low stick to high stick). All trims are zero.
Does anyone know what the issue might be?
Thanks,
Duncan Havreluck Cambridge Ontario Canada
Align 470LM DX8G2/AR7700 using SRXL port ESC (stock) Align RCE-BL50X Spirit Pro / BT-Android Savox servos 257/262
Coco66
Posted: Sat 17. Jun 2017 10:30:10 |
What exactly does not work in calibration?
Posted: Sat 17. Jun 2017 13:08:40 |
firstly, it is important that you have Governor disabled in the unit (if used). Can you tell me what Throttle range do you have configured in the General - Throttle/Governor? Min. and Max. values are important for this - to make it work. Default is 1100 - 1900us which should work with mostly any ESC except CC.
DHavreluck
Posted: Mon 19. Jun 2017 15:13:07 |
Thank you Mr. Site Admin, I never previously entered the throttle/governor setting area. I made the setting as you described and the ESC calibration initializes as expected and the throttle range now seems correct - rotor spool-up starts at about 12% stick.
Thanks for the advise.
Posted: Tue 20. Jun 2017 21:18:42 |
Perfect, thank you for the details!
[ 5 posts ] |
Users browsing this forum: The Gasman and 56 guests |
