It is currently Sun 24. Nov 2024 5:34:42
PostPosted: Fri 16. Jun 2017 12:05:49
I have been having an issue with my throttle.
I have attached my Spirit file and my Jeti model file.
I have my Castle ESC set for fixed end points at the moment, but will change it to Airplane mode once I get this sorted and start to use the spirit governor.
The throttle curve is linear 0, 50, 100.
But the throttle response is like this, I will go from 0, the when I get to 50 on the curve I actualy have 100% throttle, then when I get to approximately 55% on the curve, you can hear the motor rpm drop slightly, then as you carry on through the throttle curve back to 100%, you have full motor RPM again.
The first thing I checked was the throttle curve, as I said above it is a straight linear curve. Then I attempted to re-calibrate the esc, it wont let me calibrate the top end point, but when I bring the stick back down, I can calibrate the lower end point.
Could the throttle sensor be giving me this problem?
I have looked at what would be the obvious, can someone shed some light on this please.
450L Setup.4ds [255 Bytes]
Downloaded 31 times
PostPosted: Fri 16. Jun 2017 12:34:20
the problem is caused, because you have Governor enabled in the unit.
If you are using governor, then using a throttle curve other than flat is not optimal.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
