It is currently Sun 24. Nov 2024 4:07:36
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Micro Spirit wiring
PostPosted: Sun 04. Jun 2017 13:25:31
OK Thanks for the info. I had bought Lynx adapters and the Red and Black wires ARE switched at the JST connector so I should be good go.
As soon as US Postal system gets around to delivering mine :lol:
PostPosted: Sun 04. Jun 2017 13:30:34
Tomas,
Just out of curiosity; what is the intended purpose of the adapter cable that has the Futaba connector with female socket terminals?
PostPosted: Sun 04. Jun 2017 13:33:26
Mine will be going in a Blade 230 which has a Tail Rotor Motor. Is Tail Gain set the same way ?
PostPosted: Sun 04. Jun 2017 13:41:39
Yes, same as when you are using servo for rudder.
You only have to set Motor as the Rudder control type in the Wizard.
PostPosted: Sun 04. Jun 2017 18:29:39
Tomáš, I think we all need a sort of diagram on the online manual to make sure these things are clear... I will receive my uSpirit tomorrow, and I bought the Lynx adapters... I wanna make sure they are fine, but I need a visual reference ("the closest pin" and "the last pin" do not mean much to me).
I was planning to use them for the tail servo and the USB adapter, now I am not sure...
PostPosted: Sun 04. Jun 2017 18:45:51
I hope that this will help.
Pin layout is same with for example uBrain and other units that are using JST-ZH connectors.
So once you will use our or compatible adaptors, it can't be connected wrongly.
Also no modification for Spirit USB interface or other peripherals is needed.
PostPosted: Sun 04. Jun 2017 18:49:31
Coco,
I bought the Lynx adapters also, I checked the wires they will be fine.
At Futaba end its White, Red, Black and at the JST end its White, Black, Red.
Users browsing this forum: No registered users and 43 guests
