It is currently Sun 24. Nov 2024 4:12:25
 Post subject: Governor and SRXL
PostPosted: Thu 25. May 2017 2:28:55
I'm installing a new Spektrum AR9030T receiver and connecting it to the Spirit (not pro) with an SRXL connection. Will the SRXL connection pass the RPM telemetry signal from the receiver to the Spirit so the Spirit governor can be used or does the RPM sensor have to be connected directly to the Spirit to use the Spirit governor?
I'm thinking that would be too good to be true but it doesn't hurt to ask. Thanks
 Post subject: Re: Governor and SRXL
PostPosted: Fri 26. May 2017 7:05:58
when the RPM sensor is not present, RPM data are displayed from the ESC. So it support both.
PostPosted: Fri 26. May 2017 16:52:35
Thanks,
I have a magnetic RPM sensor connected to the receiver. Gas engine servo for throttle. Any way to pass RPM signal from the RX to Spirit in order to use Spirit governor?
PostPosted: Sat 27. May 2017 4:29:41
Just splice the wire and plug it in both.
PostPosted: Mon 29. May 2017 6:46:43
Question;
"Any way to pass RPM signal from the RX to Spirit in order to use Spirit governor?"
X-Bus? SRXL?
PostPosted: Tue 30. May 2017 7:38:17
You can do so always by a RPM sensor, so it is not entirely dependent on the used protocol.
Unfortunately it is not possible to pass a RPM signal from your receiver to the unit.
PostPosted: Tue 30. May 2017 14:06:05
OK, Thank you.
Users browsing this forum: Bing [Bot] and 55 guests
