It is currently Sun 24. Nov 2024 4:37:38
[ 6 posts ] |
keeny
Posted: Sun 28. May 2017 20:47:27 |
what does 90-degree velos mean......is it reversed because all I see is a bike?
Coco66
Posted: Sun 28. May 2017 21:20:58 |
Not sure of the second part of your question, but the 90 deg Velos option is for the Velos 880 heli that uses four servos for the swashplate.
keeny
Posted: Sun 28. May 2017 22:16:54 |
ah right....only I'm trying to set up a hirobo lama using the 90-degree swash plate. the elevator is at the front of the heli and all the directions work on my transmitter however for some reason most likely something I've done wrong, the elevator does not move at all when I move the heli around.
ps. when I googled velos it came up as French for a push bike.
Coco66
Posted: Mon 29. May 2017 20:39:16 |
Well, "vélo" is just French for a normal bicycle, that's it.
Does your lama have four servos?
keeny
Posted: Mon 29. May 2017 21:10:30 |
my lama has 1 servo for ailerons which has 2 rods on the one arm wich connects to both sides of the 90 swash. It then has one servo for elevator and one servo for pitch. none of which are directly connected to the swash as per ccpm but go through a mechanical mix. and the one for the rudder. My question is does the spirit unit support this mechanical mixing?
Posted: Tue 30. May 2017 7:40:01 |
Yes, this is the CCPM 90° option. Each servo is controlling a separate function - aileron/elevator/pitch.
[ 6 posts ] |
Users browsing this forum: Uplate and 22 guests |
