It is currently Sun 24. Nov 2024 22:07:36
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Wifi Link
PostPosted: Sat 11. Feb 2017 9:43:11
Hello Tomas!
The connections to my network I managed yesterday!
Everything works fine!
The only thing I still unclear is the Wifi link file.
There is one for Heli and one for Aero,
My question: If I set Aero and afterwards Heli would like to set up, I have to flashen every time the correct Wifi file? Is that correct?
Greetings, Gernot
Greetings from Gernot
PostPosted: Sat 11. Feb 2017 9:45:42
Coco66 wrote:
All explained here:
http://manual.spirit-system.com/index.p ... FIGURATION
(Choose "WiFi Client")
Hello Coco!
Thanks for your help. Had read this guide already times, but I had probably just overflown it!
When you gave me the hints, I read them again properly and now understood everything.
It all works perfectly!
LG Gernot
PostPosted: Sun 12. Feb 2017 11:38:48
????Answer
PostPosted: Sun 12. Feb 2017 12:15:20
you are right. If there is firmware for Helicopter (in the module) then the web interface (Spirit Settings) can be used only for helicopters.
If you are using Android app or PC software, you can use any firmware in the wifi module - it will work with both.
PostPosted: Sun 12. Feb 2017 12:49:45
Hello Thomas!
Thanks for the reply, now I've understood everything correctly. It works perfectly!
Can I leave the Wifi Link fly in the model, or is it better when it is expanded?
Looking forward to the new software update with WIFI and app. When will it come?
Greetings Gernot
PostPosted: Sun 12. Feb 2017 14:18:30
new testing version will be available probably later today.
When you are flying it is better that module is turned off. For this, you can use Auto Turn-Off feature.
When nothing is connected to the module, it will turn off itself after a few seconds.
PostPosted: Wed 10. May 2017 15:16:20
Hello Tomas!
I use for some time the Wifi link in my airplane, it is fixed installed and connected!
My question would be, is it really necessary to switch off the Wifi link during the flight with Auto off, or is it sufficient if you leave the Spirit Aero via the Wifi Link software?
Reason for it is, if I change briefly between countries around settings, then I must always open the hood and insert the battery briefly from us, so the Wifi link again works. Is it only recommended, because the Wifi link needs some current or because it People who do not leave the Aero in the software before they fly?
Please ask for your opinion!
Greetings, Gernot
PostPosted: Thu 11. May 2017 9:13:47
it is recommended to turn the module off or unplug the power.
If enabled, it can cause interference between receiver so that working distance can be reduced.
Otherwise it is not a problem.
