It is currently Sun 24. Nov 2024 3:45:52
 Post subject: hirobo lama
PostPosted: Mon 24. Apr 2017 15:03:38
Hi can i use this unit on a hirobo lama ?
Cheers Chris.
 Post subject: Re: hirobo lama
PostPosted: Mon 24. Apr 2017 16:53:31
Cheers Chris.
Of course, why not?
PostPosted: Mon 24. Apr 2017 17:50:15
ok next dumb question, which type swash do i select it not the usual ccpm
PostPosted: Mon 24. Apr 2017 18:34:37
Swash 1 servo, no mixing at all, spirit does that. What tx? You need to give more detail. ☺
PostPosted: Mon 24. Apr 2017 19:47:07
I've set up spirits on 5 of my helis I'm just not familiar with what type of swash to use in the spirit software for the lama
PostPosted: Mon 24. Apr 2017 22:01:54
It should be configured for CCPM 90.
You will see if the swashplate is moving correctly, but definitively it must be 90° aligned.
PostPosted: Tue 25. Apr 2017 14:48:59
Ok, I'll try that thanks for the info.
PostPosted: Mon 29. May 2017 18:10:44
ok, guys how does the spirit use ccpm 90 on the hirobo Lama when the lama doesn't use ccpm.........im confused big time.
I have it set up using ccpm 90 but elevator does not compensate when you move heli on the bench.
PostPosted: Tue 30. May 2017 7:44:07
Please verify that there is no special mode activated, since it should work with CCPM 90° well. If there is e.g. Subtrim (tuning) enabled it will do nothing when moving with the model.
When you will move with model in the aileron axis, it must control the aileron servo. When you are moving in the elevator axis, your elevator servo must be moving.
Pitch is controlled only by your transmitter so movement has no influance there.
Maybe your elevator servo is connected in the Pitch output?
PostPosted: Tue 30. May 2017 10:52:23
Ok thanks for the replies, i will go over it all and double check everything. Looks like i have managed to have 2 threads going on the same topic.
Users browsing this forum: No registered users and 61 guests
