It is currently Sun 24. Nov 2024 1:54:08
 Post subject: WiFi vs Bluetooth
PostPosted: Thu 20. Apr 2017 21:55:54
I'm looking at getting either the Bluetooth or WiFi link.
Is there any advantage to one over the other ?
My guess is if I wanted something for field tuning the Bluetooth would be best as WiFi requires the unit to be in range of my network.
Do both offer the same features or does one vary from the other in some way ?
 Post subject: Re: WiFi vs Bluetooth
PostPosted: Thu 20. Apr 2017 22:00:03
Wifi-Link has much more possibilities, can be connected with the PC software, but do not require any installed app, can be used anywhere with any device, has better range, better connection protection, ...
No, you do not need any other network for Wifi-Link. It can work as AP and Client. By default you can connect to it directly with your phone/tablet/... without any configuration.
On the other hand BT module is probably more simple to work with.
PostPosted: Fri 21. Apr 2017 7:05:19
You can't update the unit with the Bluetooth Modul, but with the Wifi-Link you can.
Bluetooth need a switch to turn off, or disconnect the power.
WiFi-Link has a automatic turn off function.
Goblin 700C Red Carbon, Cool Kosmik 200, Pyro 800-48, MKS X8 HBL 850/880 HV, Spirit-Pro, Jlog2.6GW, GPS-Logger 2
Jeti DS-16 Red Carbon+REX7
PostPosted: Sun 23. Apr 2017 22:08:46
Wifi module turns off automatically? How does this work? When spirit is active in flight?
PostPosted: Mon 24. Apr 2017 7:34:48
No, you define timeout. If there is no activity within this interval, WiFi is turned off
Odesláno z mého D5803 pomocí Tapatalk
PostPosted: Mon 24. Apr 2017 7:35:20
Activity in WiFi communication
PostPosted: Tue 25. Apr 2017 5:28:35
I'm glad to hear that. I asked the same question on the Helifreak - Spirit thread but didn't get any answer. I guess I would be better off asking here in the future.
I ordered the Wi-Fi link anyway thinking I could always make a network in the field by tethering my Android phone and having the unit connected to that network. It works fine with my Wi-Fi printer when I don't have access to a network.
Envoyé de mon SM-G920W8 en utilisant Tapatalk
PostPosted: Tue 25. Apr 2017 10:06:35
Normally you would not need that, the simplest use of the Spirit WiFi module is having the module expose and serve a WiFi network and your phone connecting to it. It acts as a hotspot (or AP as ZeXx86 mentioned).
In case you need Internet at thesame time, then you can do it the other way around, like you said, with your mobile tethering or with your home wifi. Just more complicated and rigid to setup.
PostPosted: Tue 25. Apr 2017 18:36:50
Even better. I'm new to Spirit and still have a hard time finding my way in the doc. I have not seen it explained so clearly before.
The more I learn, the more I'm excited. I can't wait to get my first unit(uSpirit).
Thank you for your explanation.
Users browsing this forum: No registered users and 36 guests
