It is currently Sun 24. Nov 2024 2:06:05
[ 5 posts ] |
scvflyer
Posted: Wed 19. Apr 2017 13:17:07 |
Hi serviceteam, setting my spirit system (standard) after update - setting channels seams to be fine. Pitch movement is shown at general channel setting as well. But if i try to use pitch under normal circumstances - it doesn't work. Second - setting direction of each channel has be done and works properly but - if Helicopter will be moved to one site (aileron) Spirit systems moves to same direction - but has to move against this direction Any idea? thanks in advance and br siggi
Adrian
Posted: Wed 19. Apr 2017 19:55:37 |
Joined: Thu 08. Oct 2015 14:43:12 Posts: 204 Location: Switzerland
Direction: This can have different reasons, usual if followed installation wizard, this should work. Causes, Spirit pointing to wrong flight direction or servo plugged in on wrong ports in Spirit.
_________________ Oxy4max SpiritPro + HW // SOXOS 550, SpiritPro, HW120A V4, 920KV // SOXOS 600, SpiritPro, HW160A, Pyro650 // SOXOS Strike7, SpiritPro, HW160A, Pyro750 // Skywing Spirit Aero // FrSky Horus X10S + Taranis X7 /
scvflyer
Posted: Wed 19. Apr 2017 22:28:47 |
Hi Adrian, I fixed one issue - dircection of contra movement while moving heli has been fixed - I set reverse movement in spirit and normal at TX. last issue - no pitch movement. Pitch traveling is shown at diagnostic tabs from spirit - therfor signal must be known at spirit
Aileron, elevator, rudder, rescue mode works fine.
Thanks supporting me br siggi
jgiannakas
Posted: Thu 20. Apr 2017 7:03:18 |
If you're not getting any pitch (collective) you have rescue enabled & active.
scvflyer
Posted: Fri 21. Apr 2017 11:55:42 |
Hi jgiannakas, you are right - I have a mixer at TX and this doesn't work properly (after updating TX Software). thanks and br Siggi
[ 5 posts ] |
Users browsing this forum: No registered users and 36 guests |
